12 years agoHow do I synchronize gray code counts safely across asynchronous clock domains?
I have a design for a generic asynchronous FIFO that I have used for many years. In this FIFO, I use gray code counters for the read and write pointers to the core memory. These multi-bit pointers mu...
12 years ago --- Quote Start --- Unfortunately, set_max_skew pays attention to the set_false_path. Because of the set_false_path, Timequest will say there is nothing to report in the "Report Max Skew Summary". The set_max_delay would be correct, but there is no way to say "datapath_only" and have it ignore the clock trees. --- Quote End --- First you may remove set_false_path and ignore any reported violations or set to some high multicycle. second, this is an altera example that involves data path only: # Create a max skew constraint that includes only data path arrival set_max_skew -from [get_keepers inst1|*] -to [get_keepers inst2|*] 0.200 -exclude { from_clock to_clock clock_uncertainty }
