12 years agoHow do I synchronize gray code counts safely across asynchronous clock domains?
I have a design for a generic asynchronous FIFO that I have used for many years. In this FIFO, I use gray code counters for the read and write pointers to the core memory. These multi-bit pointers mu...
12 years agoUnfortunately, set_max_skew pays attention to the set_false_path. Because of the set_false_path, Timequest will say there is nothing to report in the "Report Max Skew Summary". The set_max_delay would be correct, but there is no way to say "datapath_only" and have it ignore the clock trees.
