12 years agoHow do I synchronize gray code counts safely across asynchronous clock domains?
I have a design for a generic asynchronous FIFO that I have used for many years. In this FIFO, I use gray code counters for the read and write pointers to the core memory. These multi-bit pointers mu...
12 years agoWell in that case try set_max_skew
This is something I haven't tried but reading through its description it may be just what you want as it can exclude clocks
