shreenithi
4 years agoHow do I get OPAE on oneAPI?
I couldn't find OPAE in my oneAPI devcloud, and I can't install it easily without root access. How do I get OPAE?
- 4 years ago
Hi @shreenithi,
Thank you for posting in Intel community forum and hope all is well.
There seems to be a problem in the Arria10 nodes for now, hence would suggest to use the Stratix 10 - OneAPI, OpenVINO nodes.Once in the nodes, use the 'tools_setup' command to complete the setup, selection the options #7, that should source the required opae resources.
To verify, you may use the following command 'echo $OPAE_PLATFORM_ROOT', it should produce an output of the opae path.
Hope that clarify.Best Wishes
BB
BoonBengT_Altera
Moderator
4 years agoHi @shreenithi,
For the OPAE library it should be in the sw folder.
As for the include folder I am unsure which type you are looking for, perhaps you can use the find command in linux to perform some searching.
Hope that clarify.
Best Wishes
BB
