11 years agoHow do I determine FPGA image size within a POF
Hello all. I have searched around and can't find quite the answer I'm looking for so I'm hoping that I can get some help here. First a little background. I am attempting to create an applicat...
9 years agoHi,
Near the end of .pof file, you can see, as Dsl said, "mPage_0 00000000 0226A5F8;" the last number seems to be the data size in bits.does it mean that i can write user data, to epcs, from offset (0x0226a5f8 / 8) ? (through ASMI_parallel component) note : you can know the size of programming data with :
sof2flash --input=your_sof_file.sof --ouput=dummy.flash --offset=0x00
nios2-elf-size dummy.flash
this size, in bytes, may be different from (supposed) data size in bits found at the end of .pof file because of compression (see quartus>asignments>devices...)
