12 years agoHow do I add interrupt-names parameter to the device tree?
I'm trying to use mSGDMA and am looking at the interrupt-names field in the device-tree-source of the gmac and see this:
hps_0_gmac0: ethernet@0xff700000 { compatible = "synopsys,dwmac-1.0", "altr,socfpga-stmmac", "snps,dwmac-3.70a", "snps,dwmac"; reg = < 0xFF700000 0x00002000 >; interrupt-parent = < &hps_0_arm_gic_0 >; interrupts = < 0 115 4 >; interrupt-names = "macirq"; /* embeddedsw.dts.params.interrupt-names type STRING */ mac-address = "[00 00 00 00 00 00]"; /* embeddedsw.dts.params.mac-address type STRING */ address-bits = < 48 >; max-frame-size = < 1518 >; local-mac-address = [ 00 00 00 00 00 00 ]; clock-names = "stmmaceth"; /* appended from boardinfo */ clocks = < &emac0_clk >; /* appended from boardinfo */ status = "disabled"; /* appended from boardinfo */ }; //end ethernet@0xff700000 (hps_0_gmac0) which appears to allow the device driver to call platform_get_irq_byname with the specified name. How can I get a name that I can use with platform_get_irq_byname into the device-tree, short of editing it by hand?1 Reply
Use DTAppend command in the board info file while creating device tree using soc2dts tool.
http://www.rocketboards.org/foswiki/documentation/gsrdv1402devicetreegenerator#dtappend_tag Refer http://www.rocketboards.org/foswiki/documentation/gsrd1402devicetreegenerator to use board info while creating dtb/dts file --- Quote Start --- I'm trying to use mSGDMA and am looking at the interrupt-names field in the device-tree-source of the gmac and see this: hps_0_gmac0: ethernet@0xff700000 { compatible = "synopsys,dwmac-1.0", "altr,socfpga-stmmac", "snps,dwmac-3.70a", "snps,dwmac"; reg = < 0xFF700000 0x00002000 >; interrupt-parent = < &hps_0_arm_gic_0 >; interrupts = < 0 115 4 >; interrupt-names = "macirq"; /* embeddedsw.dts.params.interrupt-names type STRING */ mac-address = "[00 00 00 00 00 00]"; /* embeddedsw.dts.params.mac-address type STRING */ address-bits = < 48 >; max-frame-size = < 1518 >; local-mac-address = [ 00 00 00 00 00 00 ]; clock-names = "stmmaceth"; /* appended from boardinfo */ clocks = < &emac0_clk >; /* appended from boardinfo */ status = "disabled"; /* appended from boardinfo */ }; //end ethernet@0xff700000 (hps_0_gmac0) which appears to allow the device driver to call platform_get_irq_byname with the specified name. How can I get a name that I can use with platform_get_irq_byname into the device-tree, short of editing it by hand? --- Quote End ---
