16 years ago
how convert hex file from epm7032s to epm7064s
can help me...
how to convert hex file(firmware) epm7032s to epm7064s????
    You do not need a pof file for erase action, because a pof file contains configuration bits necessary for programming only. I am absolutely sure about this. You should explain to the company with a device programmer you need just device erasing.
    BR,
    Martin
    Thanks, that's the tough part. The company that has the programming hardware wants a .pof file that they can use to program the devices. Erasing doesn't seem to be an option?
    I'm confused.
    You should erase these devices with help of a device programmer that is able to erase a device with parallel algorithm instead of JTAG algorithm. After such an action JTAG engine will be operative again.
    Martin
    Not an answer but another question...
    How can I get an erased .pof file for an EPM7032SLC44 device?
    I bought a bunch of surplus 7032SLC devices that have had their JTAG pins programmed as I/O so they can't be programmed via JTAG
    Thanks in advance.
    --- Quote Start ---
    but i only have hex/bin from my universal progammer
    --- Quote End ---
    as far as I know there is No way to convert the hex-file to a different CPLD device.
    Kind regards
    GPK
    --- Quote Start ---
    can help me...
    --- Quote End ---
    do you want to transfer an EPM7032 design to a EPM7064 ? In this case you have to ru-run your project with the new device choosen.
    Kind regards
    GPK
