14 years agoHow connect 2 FPGA ?
hi, I want to connect many IO between 2 Cyclone III located on two different cards. I have to make an impedance matching or can I connect them directly ? Best regards
14 years agoSuch a design might have to tackle some significant SSO noise. That’s what differential signaling – with or without an accompanied clock – is all about. It’ll require twice the pin count but can transfer way more than twice the data rate at significantly reduced SSO problems and power needs.
Can you explain what stops you from using LVDS? – Matthias
