How can we add our own recipes to meta-intel-fpga layer to build rootfs
I am following the below documentation to build custom linux image for Arria10 SoCDK. Initially, I followed the steps mentioned in the documentation to get familiarize with the process and the image size turned out to be 82MB. After adding the custom recipes in rootfs-->meta-intel-fpga layer and custom dts whie building kernel image, I rebuilt the image, but the size of the image remains unchanged. I am not sure if I followed correct steps in adding recipes? Any help would be appreciable.
Sai
- Jeet14
I believe your inquiry has been answered. With that now, I transition this thread to community support.
Thank you.
Tiwari
- Jeet14
Its fine you can use the same layer.
add you application in above socfpga-gsrd-apps_1.0.bb file and add your application source code in below-
https://github.com/altera-opensource/linux-refdesigns
Tiwari
- Jeet14
Please follow the below link for understanding and creating custom/own layer using the yocto.
https://docs.yoctoproject.org/dev-manual/layers.html
Also, please follow the below link for how to customize image using the local.conf file.
https://docs.yoctoproject.org/dev-manual/customizing-images.html#
Tiwari
- sgannava
Hi Tiwari,
Thanks for the response
I have added my files as recipes in meta-intel-fpga layer itself without creating a new layer. Now I do not need to add/edit any layer .conf file as well. Hope that is also fine
Sai
