14 years ago
How can i tie an input port of my top module to a fixed value using the tool settings
Hi all,
I have a signal as an input port from the top which will give a reset value to registers at reset.
suppose an example like
if(rst_n==1'b0) begin
x<=a;
else
x<=s;
Now tool is converting this register into a latch and in the timing reports the path consists of a loop. the tool also issues a warning of a combinational loop for this signal.
So i want to tie this signal (a) which is an input port of my system to some value in order to tell the tool that it will have a static value and not a variable one, which the tool is understanding .
So any qsf assignment if known do help me out.
    sorry chris i dint gave complete info...the assignments are in a sequential logic only..i mean the sensitivity list has the clock...sorry for the confusion
    If you really need x to be a register, you should use a clock and include your code into a
    always @ (posedge clk) block.
    In the way you are using x here, a combinatorial assignment is enough:
    assign x = (rst_n==1'b0) ? a : s;
    and x should be defined wire instead of reg
