14 years ago
How can i make bidirectional pins virtual? :(
I am working on a design with bidirectional interfaces having an io count of more than 2000. I want to fit the design on a device and check its timings. But the max available pin count is hardly 1000.
I cant use the virtual pin assignment as it is ignored for bidirectional pins.
Is there anyother way to fit the design ?
    Yes you mean to say a wrapper...i am doing that only ...thanks tricky...
    you could also create a dummy file that sepatates the bidir busses into separate in and out, and then make all the pins virtual.
    now that i think about it, this still may not work. anyhow...
    1. port map the bidir bus to an HDL file that defines the bidir I/O but nothing else
    2. run Analysis and Elaboration
    3. find the bidir dummy module in the Hiearchy window
    4. right click and create a new parition
    5. in Assignments > Design Partitions change the Netlist Type for the dummy partition to Empty
    hi pancake can you tell me more about empty partition...THANKS
    Yes i know...but i am doing a module level synthesis. This module has some huge combo logic and i want to be aware of the timing so that i dont have probs at the top.
    Now coming back to interfaces , these wont be in the port list in the top, so i just want to do a module level synthesis as i doubt that this module might cause timing probs when i integrate it.
    So can you help me as to what i can do regarding this?
    why do you have more than 2000 bidirections IOs? how do you expect these to work on a real chip? Bidirs internally are converted to muxes. Bidirectional signals should really only be connected to a pin.
    If they were coded as separate ins and outs (as they will end up as eventually anyway) then you could easily use virtual pins.
