15 years ago
How can I get 5.0V FPGA digital signal output?
Hello, everyone.
My name is Ray.
My device is Max 7000 series, EPM7128SLC84-7.
I need 5.0V timing clock, and I set all vccio and vccint at a level at 5.0V power supply.
However, the outputs still remain 3.3V.:confused:
I'd like to ask is there something wrong in my setting?
Thanks for your kindness.:)
    Thank you, FvM.
    In the datashht " Max 7000 Programmable Logic Device Family ",
    In page 20, it shows that "The VCCIO pins can be connected to either a 3.3-V or a 5.0-V power supply, depending on the output requirement."
    I just wonder how to set the VCCIO pins.
    I 've checked the output again, and output is at a level 3.3V(digital timing clock).
    The hole number for VCC is 5.0V under measurement.
    Thanks for kind reply.
    Ray
    I was under the impression up to now, that MAX7000S series is actually a 5V device. Although there's only a TTL level specification in the datasheet, I can't imagine, why the unloaded output of a CMOS device shouldn't achieve 5V high level? I suspect a problem with your measurement.
    Thank you, Actris.
    I used some logic IC to pull-up the output of FPGA before, but there is rise/fall time limitation(10nS) in my application.
    As a result, I change to use a 5V FPGA to get better transition performance.
    Thanks for your kind reply.
    Ray
    You need to use buffer like an 74AC541 to translate from 3.3V to 5V. or you can use an mosfet for single output.
