15 years ago
hostpc like send data to nios II via jtag (nios2-terminal.exe, jtag_atlantis.dll)
hi!
my system:
cyclone 3 starter kit
quartus 2 - 9.1 ( licence + nios licence)
nios 2 system working
goal:
i want to setup a matlab gui to switch some pio outputs of the nios. with it i want set the options of a dsp-builder-block. i also want to check some pio-inputs in my matlab gui and do something if bit 0 switches from 1 to 0 or something like that.
i think i can do this by sending chars by alt_getchar() (small c lib) with the nios2-terminal.
the problem is that when i start a *.m file and the nios2-terminal is waiting of my input, i have no ability to put in the char automatically via a programmed *.m file.
i am also open for other hardware suggestions.
Problem:
only a usb-blaster-connection to the board - want no other connection.
i am connected via the integrated usb blaster to the starter board.
i need a possibility to send just a few bit to the nios via the usb (jtag uart).
in my opinion - the nios 2 ide is also transfering data to the sopc -system by using nios2-terminal.exe.
i read the example" high speed image download demo " but could not understand how its done. i am just a beginner with nios and also not so well in programming/compiling to understand how to use the cygwin - environment. - ok i looked in the inet - is a linuxlike environment for windows.
i also thought about using the fdti-usb driver (set up a virtual serial connection - vcp or d2xx).
i have no idea if it is possible so easy (without programming a new driver or something like this)
what exactly can i do with nios2-terminal and how?
(the ' --help' makes no reason for me)
does anyone of you understand what i am talking about?
need real help!!!
greets
