8 years ago
HLS run Quartus compile FAILED.
My HLS quartus complies fails with following error, although synthesis is successfully.
Info: Running Quartus Prime Synthesis
Info: Version 17.1.0 Build 240 10/25/2017 SJ Pro Edition
Info: Processing started: Mon Jul 23 09:02:12 2018
Info: Command: quartus_syn --read_settings_files=off --write_settings_files=off quartus_compile -c quartus_compile
Info: Using INI file /home/tempuser11/counter/counterDUT1.prj/quartus/quartus.ini
Info: qis_default_flow_script.tcl version:# 1
Info: Initializing Synthesis...
Info: Project = "quartus_compile"
Info: Revision = "quartus_compile"
Info: Analyzing source files
Error (19286): No license for family Arria 10
Error: Flow failed: ERROR: Current design not found
Error: Quartus Prime Synthesis was unsuccessful. 2 errors, 0 warnings
Error: Peak virtual memory: 868 megabytes
Error: Processing ended: Mon Jul 23 09:02:12 2018
Error: Elapsed time: 00:00:00
Error: Total CPU time (on all processors): 00:00:01
Error (293001): Quartus Prime Full Compilation was unsuccessful. 4 errors, 0 warnings
Error: Flow compile (for project /home/tempuser11/counter/counterDUT1.prj/quartus/quartus_compile) was not successful
Error: ERROR: Error(s) found while running an executable. See report file(s) for error message(s). Message log indicates which executable was run last.
Error (23031): Evaluation of Tcl script /D/intelFPGA_pro/17.1/quartus/common/tcl/internal/qsh_flow.tcl unsuccessful
Error: Quartus Prime Shell was unsuccessful. 11 errors, 0 warnings
Error: Peak virtual memory: 696 megabytes
Error: Processing ended: Mon Jul 23 09:02:14 2018
Error: Elapsed time: 00:00:14
Error: Total CPU time (on all processors): 00:00:05
    It looks like you do not have license for compiling for Arria 10 FPGA. Either check what license you have or use another device which you have license for.
    --- Quote Start ---
    My HLS Quartus complies fails with the following error, although synthesis is successful.
    --- Quote End ---
    Can you elaborate more on the steps or attach complete log?
    Anand Raj Shankar
