15 years agoHighest frequency on EP2C5 ?
Hello : Anybody knows what is the highest frequency can be obtained from EP2C5's inside PLL? my input clock is 50Mhz anybody knows?
15 years agoWhy don't you consult the Cyclone II hardware manual? Basically, the limitation isn't in the PLL rather than the maximum core clock respectively output toggle rate. So the answer depends on what you want to use the clock for, also on the device speed grade and the involved I/O standard.
