14 years agoHigh Speed Embedded Memory
Hello guys, We are in process of designing a new embedded high performance data acquisition platform. Basically, we have let’s say 400 ADC channels which each channel is 16 bit wide and we need to...
14 years agoIDE CF card looks like the best options.
Some more random thoughts: There are SATA cables with clips. But they might not be good enough for the needs. Another option: solder the flash chips directly on the board and use a Flash file system (JFFS2 or YAFFS2). Yet another option: consider more mechanically rugged connection options. For example, Ethernet over AUI uses connectors with screws.
