10 years agoHigh bandwidth data transfer between hps and fpga
Hi, I need to High bandwidth data transfer between hps and fpga. Which bridge should i use? I used light weight bridge but the speed of transfer data was up to 3MHz. Best Regards
9 years ago --- Quote Start --- As a general rule of thumb the highest speed method of moving data between the FPGA and HPS is to use the FPGA-to-SDRAM interface. If you require the FPGA to have access to cacheable data then that's the exception to the rule and you would use the F2H bridge (and a master in the FPGA) instead. I would stay away from moving data between the FPGA and HPS using the MPU or DMA inside the HPS which is why that design sunshine pointed to doesn't bother to implement it. --- Quote End --- I have followed the example which sunshine recommended and make my system works as: 1. Load my data in FPGA layer to a FIFO 2. Using msgDMA to transfer data from the fifo to a sdram port, lightweight h2f bridge is used to control msgdma only. 3. In my linux application, I read the data from sdram using mmap and it worked well. However, there is some troubles 1. The read data from sdram will be processed with some heavy works such as applying filter, image processing, and using TCP/IP to transfer the processed data to other host PC. All the heavy works make my kit slow down and effect to the sampling frequency of my data in fpga. Therefore, I'm thinking of transferring my data directly from the sdram to ethernet using the HPS EMAC controller and my question is how do I configure some parameters of TCPIP socket as the host IP address, port, etc. I'm expecting to achieve highest bandwidth as high as possible. 2. My flow is too complicated now, data(fpga) --> fifo --> dma --> sdram --> dma --> ethernet emac --> TCPIP--> host PC. but it's the easiest flow I can merge from multiple examples on the internet. Could you give me some advice to simple the flow?
