10 years agoHigh bandwidth data transfer between hps and fpga
Hi, I need to High bandwidth data transfer between hps and fpga. Which bridge should i use? I used light weight bridge but the speed of transfer data was up to 3MHz. Best Regards
9 years ago --- Quote Start --- Hi sunshine, Thanks for the reference link, but I can't compile the fpga project to make the output file .sof compatible with my kit. Beside, the hps_system.qsys is missing 3 subcomponents: AXI_cache_security and custom_reset_synchronizer_50, custom_reset_synchronizer_fast. Could you give me some advice to make it work? I'm expecting to transfer data between FPGA and linux application with bandwidth >= 60MB/s ~ 480Mb/s and I wonder whether this example can reach this requirement I'm using DE1-SOC kit and Quartus 15.0. --- Quote End --- You'll need to Open Qsys and generate the HDL files first. After that, then you can compile the design
