10 years agoHigh bandwidth data transfer between hps and fpga
Hi, I need to High bandwidth data transfer between hps and fpga. Which bridge should i use? I used light weight bridge but the speed of transfer data was up to 3MHz. Best Regards
10 years agoIn this example
https://rocketboards.org/foswiki/view/projects/datamover it looks like the transfer from FPGA to HPS bridges are happening at 133MHz (multiply that with 128-bit, so 2.1GB/s assuming that the pipeline can be saturated) It you just wanted to access the HPS SDRAM and do not need coherency, you can use the FPGA-to-SDRAM bridge instead - here's an example implementation: https://rocketboards.org/foswiki/view/projects/cyclevsocsdramperformanceexampledesign Hope this helps...
