Hi Just installed Quartus prime lite and I am using a Max DE10. I am actually trying to do the beginner projects from the Intel class intro to FPGA. The Quartus software seems to be in order. When I run new project wizard and hit finish it locks and prog
Yes in short it is working. I may find other issues as I progress. Just so you know. I tried down loading and reinstalling several times. The issue is in the down load install and set-up itself. There are files and folders missing from the build. When you first create a project in wizard you have to create a folder for it. And place it in the right path. All of these issues are not listed and not so intuitive to fix. Some of them by trial and error and blind luck. As I write this I am not sure all that I did.
But thank you so much for your time and concerns in this!! I am sure I will have other questions. I am a full time student and my time is divided. I wish I had more time to explore this. We are using this DE-10 for a digital class I am taking. Intro that is..
Michael Zlab
