14 years agoHi guys, I have a question about ADC sampling using Cyclone IV.
Hi guys, I'm a green hand in FPGA coding. I have a question about ADC sampling using cyclone IV. The ADC and FPGA are AD9252 and EP4CE115F29C7 respectively. AD9252 is a device including 8 ADCs wit...
14 years agoThe data rata of ad output(ad_in2) is 700Mbps together with the DDR data bit clock(350MHZ) and frame clock(50MHZ). Its sampling resolution is 14 bit.
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use work.macro_def.all;
entity ad_control is
port(
clk_in : in std_logic;--50MHZ
rst : in std_logic;
ad_dco : in std_logic;--350MHZ
ad_fco : in std_logic;--50MHZ
ad_in2 : in std_logic;--700Mbps
ac_in2 : out std_logic_vector(AD_WIDTH-1 downto 0)
end entity ad_control;
architecture arch_ad_control of ad_control is
--the declaration of module pll
component pll is
port(
inclk0 : in std_logic := '0';
c0 : out std_logic
end component;
--output signals
signal clk : std_logic;
--the declaration of module ad_pll
component ad_pll is
port(
c0 : out std_logic
end component;
-- output signals
signal dco_clk : std_logic;
--the declaration of module ad_ddio_in
component ad_ddio_in is
port(
datain : in std_logic_vector(0 downto 0);
inclock : in std_logic;
dataout_h : out std_logic_vector(0 downto 0);
dataout_l : out std_logic_vector(0 downto 0)
end component;
--output signals
signal ad_in2_h : std_logic_vector(0 downto 0);
signal ad_in2_l : std_logic_vector(0 downto 0);
--the declaration of module ad_fifo
component ad_fifo is
port(
data : in std_logic_vector(AD_WIDTH-1 downto 0);
rdclk : in std_logic;
rdreq : in std_logic;
wrclk : in std_logic;
wrreq : in std_logic;
q : out std_logic_vector(AD_WIDTH-1 downto 0)
end component;
--input signals
signal ad_fifo_wr : std_logic;
signal ad_fifo_rd : std_logic;
--internal signals
signal ad_in2_tmp : std_logic_vector(0 downto 0);
signal ac_in2_tmp : std_logic_vector(AD_WIDTH-1 downto 0);
signal ad_fco1 : std_logic;
signal ad_fco2 : std_logic;
begin
--ad_pll instance
inst_pll: pll
port map(
inclk0 => clk_in,
c0 => clk--50MHZ
--ad_pll instance
inst_ad_pll: ad_pll
port map(
inclk0 => ad_dco,
c0 => dco_clk--350MHZ
--ad_ddio_in instance
ad_in2_tmp(0) <= ad_in2;
inst_ad_ddio_in: ad_ddio_in
port map(
datain => ad_in2_tmp,
inclock => dco_clk,
dataout_h => ad_in2_h,
dataout_l => ad_in2_l
--serdes conversion
process(dco_clk, rst)
begin
if(rst = '1') then
ac_in2_tmp <= (others => '0');
elsif(rising_edge(dco_clk)) then
ac_in2_tmp <= ac_in2_tmp(AD_WIDTH-3 downto 0) & ad_in2_l & ad_in2_h;
end if;
end process;
--synchronize the ad data
begin
if(rst = '1') then
ad_fco1 <= '0';
ad_fco2 <= '0';
ad_fco1 <= ad_fco;
ad_fco2 <= ad_fco1;
end if;
end process;
ad_fifo_wr <= ad_fco1 and (not ad_fco2);
ad_fifo_rd <= '1';
inst_ad_fifo: ad_fifo
port map(
data => ac_in2_tmp,
rdclk => clk,
rdreq => ad_fifo_rd,
wrclk => dco_clk,
wrreq => ad_fifo_wr,
q => ac_in2
end architecture arch_ad_control;
