17 years ago[HELP]question about loading different sof+elf files in remote upgrade
hello: I've completed the things about loading application sof file in remote upgrade and that is successful.Now I want to load the sof+elf file.How could i do?Can i use the ide flash programmer t...
17 years agoHi Jake, could you please share your modified boot loader? I change the boot_loader_epcs_bits_sii_siii_ciii.S under C:\altera\81\nios2eds\components\altera_nios2\boot_loader_sources, make the boot loader, convert boot_loader_epcs_bits_sii_siii_ciii.elf to hex and then update the SOF but my application image never booted.
I used Cyclone III, EPCS16, factory sof + sw image is at offset 0 of the EPCS while the application sof and its sw image is at offset 0x100000 of the EPCS. I change line 99 of the assemble code from movi r_flash_ptr, 0 to movi r_flash_ptr, 0x100000 TIA
