19 years agohelp:fpga configuration with pfl
I can write pof file into flash, but i can't configure the fpga correctly. What's the problem? Is it the pof file not corret? or the locig is wrong?
19 years agoThank you very much for young answer.
I can load sof into FPGA and work correctly. But I don't know that the pof file is correct after sof converted to pof file through Quartus II 7.1 under FILE->Convert Programming File. Also, I have checked out the Altera WEB page's self guided trouble shooters. So now, I have no ideo about what's the problem. By the way, I have checked out the signal from maxii that FPGA configuration is working, but it can't configure correctly, so it retry again and again.
