14 years ago[HELP]Flash programming Cyclone III, file issue.
Hi I'm working on a Cyclone III system and I try to put my software in the flash without using an USB Blaster. My solution is to send the binaries through an RS232 serial cable and write it i...
14 years agoTry reading back the firmware in both cases and compare what is going wrong.
Maybe that gives you a hint.
