14 years agoHelp with onboard programmer
Hi there,
I'm developing a FPGA project, I don't know yet what FPGA I will use, stratix II or newer. Is my first FPGA PCB, I have seen on internet onboard programmers using PIC but I would like to know if it possible to do a programmer like in DE2-115 so I can do onboard programming direct with quartus II without using third part programs. Is it possible? Thanks2 Replies
Thanks Dave,
I will study the cases and try one, I will post in the future my progress. Guillermo - Altera_Forum
--- Quote Start --- Hi there, I'm developing a FPGA project, I don't know yet what FPGA I will use, stratix II or newer. Is my first FPGA PCB, I have seen on internet onboard programmers using PIC but I would like to know if it possible to do a programmer like in DE2-115 so I can do onboard programming direct with quartus II without using third part programs. Is it possible? --- Quote End --- This explains how to create an on-board programmer: http://www.ovro.caltech.edu/~dwh/carma_board/fpga_configuration.pdf (http://www.ovro.caltech.edu/%7edwh/carma_board/fpga_configuration.pdf) You can implement this with a microcontroller too. If you want Quartus to recognize your programmer as a USB-Blaster, then there is no 'official' support for this. However, there are a couple of internet projects that show how to do it; UrJTAG and FPGA4U. http://fpga4u.epfl.ch/wiki/fx2 http://sourceforge.net/apps/mediawiki/urjtag/index.php?title=cable_altera_usb-blaster Cheers, Dave
