15 years agoHelp with Efficient Conversion?
I am looking to convert a 16bit number(X) to another 16 bit number(Y). X is a count coming from a Tach output on a Fan. Y is the fan's corresponding RPM. (note: this is a inverse relationship) ...
15 years agoif the clock rate is much higher than the sample rate, you can TDM or channelize your arithmetic to save resources
