help with coding 4bit adder on vhdl
I've been having trouble with coding this simple full adder on VHDL with structural coding more specifically using components
and here's my code :
Library ieee;
use ieee.std_logic_1164.all;
Entity 4bfa is
port( A : In std_logic_vector (3 downto 0);
B : In std_logic_vector (3 downto 0);
cin : in std_logic;
cout: out std_logic;
Sum : out std_logic_vector (3 downto 0) );
end 4bfa;
architecture my of 4bfa is
cin := 0;
signal c0,c1,c2,c3,s1,s2,s3,s4 : std_logic;
component fastructural is
port ( I1,I2, ci: IN std_logic;
co,s : out std_logic);
end component;
begin
u1 : fastructural port map( I1 => A(0),
I2 => B(0),
ci =>cin,
co=>c0,
s=>s1);
u2 : fastructural port map( I1 => A(1),
I2 => B(1),
ci =>c0,
co=>c1,
s=>s2);
u3 : fastructural port map( I1 => A(2),
I2 => B(2),
ci =>c1,
co=>c2,
s=>s3);
u4 : fastructural port map( I1 => A(3),
I2 => B(3),
ci =>c2,
co=>c3,
s=>s4);
cout<=c3;
Sum<="s4&s3&s2&s1";
end my;and he is the errors that I get :
Error (10500): VHDL syntax error at 4bfa.vhd(4) near text "4"; expecting an identifier
Error (10500): VHDL syntax error at 4bfa.vhd(11) near text "4"; expecting an identifierAlso for the fastructural componant is a componant of a full adder for one bit that I already have on another VHDL code and that works just fine.
but I still don't know what is the issue.
- Vicky1
Have you resolved the issue?
Best Regards
Vikas Jathar
- Vicky1
Basically basic identifiers are used for naming design entities & basic identifier must begin with a letter so in this case entity name must start with letter like 'fa4b'.
Best Regards
Vikas Jathar
