15 years agohelp with 1 to 8 Demux
Hi all, I am tried to write VHDL code for 1 to 8 Demux and that's what i finish with it LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; use ieee.std_logic_unsigned.all; ENTITY Dmux1...
15 years agoDid you mean "Selector"?
if this is the case, why should you insert by GENERATE statement? If the following signals: inputs : std_logic_vector (7 downto 0); select : std_logic_vector (2 downto 0); output : std_logic; Then just write the following combinatorial code: output <= input (to_integer(unsigned(select))); the "unsigned" function tells VHDL to threat the "select" bus as UNSIGNED, with no negative numbers interpretation. the "to_integer" function converts the "select" bus to integer value so i may be used for indexing the "inputs" array. don't forget to add the libraries, like these ones: use ieee.std_logic_unsigned.all; use ieee.numeric_std.to_integer;
