17 years agoHelp using verilog files in Quartus
Hi, I’m a beginner using FPGAs and also programming in Verilog or VHDL. I have two Verilog files created in the same Quartus 9.0 project, lets say file A and file B. File B finishes a process tha...
17 years agoDepending on what you are doing, you may not need to do this at all. If for instance all you are doing is referencing other modules, the tool (Quartus) will automatically find the other module assuming you've set up your project paths and files appropriately.
A "`include" directive is like copying and pasting the code from the other file into the present file. Jake
