15 years agoHELP: Sound generation on the DE1 board
I have a project that involves sound generation off of the DE1 board. By default, the flash memory of the DE1 board is programmed with a code that will generate a 1kHz sine wave. I took a look...
15 years ago --- Quote Start --- Yes, i know how. Um, Does that make sense to you? Do you understand the question? --- Quote End --- Can you help me figure out what I need to generate the 1kHz wave? It seems I need : Some I2C interfacing A case statement of values for the wave. Not sure what else. I'm not really sure I understand how it actually generates the sound though. Any help at all would be good.
