14 years agohelp please......frequency divider
how to convert 25Mhz to 1hz,2hz till 10 hz....? and use level select to select the frequency..this is the detail: level 1-10 will select to frequency 1Hz to 10Hz.. i just can do till 1 Hz o...
14 years ago --- Quote Start --- what is the function of Reset? if i take out the reset what will happend? i just want 1 input only.... --- Quote End --- Maybe you should just take an 'incomplete' grade for this assignment.
