14 years agohelp please......frequency divider
how to convert 25Mhz to 1hz,2hz till 10 hz....? and use level select to select the frequency..this is the detail: level 1-10 will select to frequency 1Hz to 10Hz.. i just can do till 1 Hz o...
14 years agoYou should see it like clock signal (low one half period then high).
But your frequencies are too low for simulation (on 25MHz system clock) so you will probably just see no change on Q if simulation is that short. The remedy is to wait for hours or days. Or try testing higher frequencies e.g. 1MHz, 100Khz, 10KHz. The other alternative is (in hardware or even simulation) is to use frequency meter on Q signal (count up number of 25MHz clocks per period of Q) then leave it overnight covering all selections and check in early morning.
