14 years agohelp please......frequency divider
how to convert 25Mhz to 1hz,2hz till 10 hz....? and use level select to select the frequency..this is the detail: level 1-10 will select to frequency 1Hz to 10Hz.. i just can do till 1 Hz o...
14 years ago --- Quote Start --- how to convert 25Mhz to 1hz,2hz till 10 hz....? and use level select to select the frequency..this is the detail: level 1-10 will select to frequency 1Hz to 10Hz.. --- Quote End --- A counter that counts down from either 12,500,000 (1 Hz); 6,250,000 (2 Hz)...1,250,000 (10 Hz) would be a place to start. When the counter counts down and rolls over from 0 back to the max listed above, then toggle the output clock. --- Quote Start --- i just can do till 1 Hz only but still dont know whether its correct or not....:( tq.... --- Quote End --- Use a simulator and measure the output clock period. Kevin Jennings
