15 years ago[Help on VHDL] FATAL ERROR while loading design
Hi guys, I've just started learning VHDL for a week on my own so i'm still very new to it. I'm doing a practice on implementing a 4-bit parallel-out serial shift register.. My codings can be complied...
15 years agoThanks for the help Tricky! I got it working now.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity shiftreg is port (
A: in std_logic; -- data in
B: in std_logic;
clk: in std_logic; -- Clock
clr: in std_logic; -- Clear
preset: in std_logic; --Preset
q : out std_logic_vector(3 downto 0) -- output Q
end;
architecture rtl of shiftreg is
signal q_int : std_logic_vector(3 downto 0);
begin
process (clk, clr,preset)
begin
if (preset='0') then
q_int <= "1111";
elsif (clr='0') then
q_int <= "0000";
elsif (clk'event and clk = '1') then
q_int(0) <= A and B;
q_int(1) <= q_int(0);
q_int(2) <= q_int(1);
q_int(3) <= q_int(2);
end if;
end process;
q <= q_int;
end rtl; Bu how do i write a test bench? I tried writing one myself i think it's pretty messed up and it doesn't seem to produce the waveform i wanted. Testbench Library IEEE;
Use IEEE.std_logic_1164.all;
Entity shiftregTB is
end;
Architecture rtl of shiftregTB is
signal A,B,clk,clr,preset: std_logic;
signal q,q_int : std_logic_vector(3 downto 0);
begin
UUT : entity work.shiftreg port map(A,B,clk,clr,preset,q_int);
tb : process
begin
preset<='0';
wait for 10 ns;
preset<='1';
wait for 10 ns;
clr<='0';
wait for 20 ns;
clr<='1';
wait for 20 ns;
clk<='1';
wait for 20 ns;
A<='1';
wait for 30 ns;
B<='1';
wait for 30 ns;
A<='0';
wait for 40 ns;
B<= '0';
wait for 50 ns;
end process tb;
q<=q_int;
end;
