17 years agohelp ON EP2S60 FPGA
The FPGA refuse to work after I program it! I use two way to program my design, one is programming to EPC16 which is connect to FPGA, another is programming to FPGA directly. but FPGA has no rea...
16 years agoYes I allready did that, it's a Mezzanine board normally tested in a system.
But also possible to test it seperately. It's not only the TDO but I think the complete TAP is disappeared after erase with quartus. I tried to put the device in extest but nothing happened. The only thing I can think of is that the erase action is writing something in the private registers ( see the last lines from the ep2s60 bsdl) : "The following private instructions must not be used as they"& "may render the device inoperable:"& " "& " 1100010000 "& " 0011001001 "& " 0000101001 "& " 0000010000 "& " "& "Customer should take precautions not to invoke these instructions"& "at any time. Contact Altera Applications for further assistance.";
