17 years agohelp ON EP2S60 FPGA
The FPGA refuse to work after I program it! I use two way to program my design, one is programming to EPC16 which is connect to FPGA, another is programming to FPGA directly. but FPGA has no rea...
16 years ago --- Quote Start --- I am using the USB byte blaster rev B. Before I do a Erase action the Quartus (9.0) and do auto detect the chain is seen correct. Both with the USB blaster and the Jtag Technologies hard/software. Now starts the problem : after I do a "erase" with quartus and do a power dwn up again there's no chain seen with both tools (JT and USB blaster). The TDO is only high ( it looks like high Z). Hans --- Quote End --- Hi Hans, is it possible for you to change the JTAG Chain, so that only your Stratix Devcie is in the Chain ? Kind regards GPK
