17 years agohelp ON EP2S60 FPGA
The FPGA refuse to work after I program it! I use two way to program my design, one is programming to EPC16 which is connect to FPGA, another is programming to FPGA directly. but FPGA has no rea...
16 years ago --- Quote Start --- I did not noticed If programming was successful, I found out after programming that the device did not configure ( via epcs64 and quartus 9.0). But my problem is now that the normal boundary scan test passed before programming the device , did some ddr ram test with boundary sacn ,all ok. Then I came to the conclusion that I was using the wrong programming file and used Quartus 9.0 to erase the epcs64 . After this erase : I can not use the EP2S60 anymore, not with the USB blaster , not with the standard boaundary scan tools . I looks like the TAP controller is not working any more. I thought it was board dependend but when I tried this on the second board with a EP2S60 : the same problem after the erase . TAP is not working !! Am I the first with this problem ? Tnx Hans --- Quote End --- Hi, what kind of programming HW do you use (USB-Blaster?) ? What happend when you choose "Auto detect" in the programmer ? What HW is selected ? Kind regards GPK
