17 years agohelp ON EP2S60 FPGA
The FPGA refuse to work after I program it! I use two way to program my design, one is programming to EPC16 which is connect to FPGA, another is programming to FPGA directly. but FPGA has no rea...
16 years ago --- Quote Start --- Maybe it has nothing to do with this problem. I am having a EP2S60 but the configuration file was compiled for a EP2S130. Programmed the device with the wrong file. Tried to erase ( with the byte blaster) but I can not get connect to the device anymore. Also with Boundary scan tools (Jtag Techn) there's no reponse (TDO is continue 1) rgrd's Hans --- Quote End --- Hi Hans, you tried to programm a EP2S60 with a file for an EP2S130 ????:confused: I don't think that the programmer will finish successful. Kind regards GPK
