17 years agohelp ON EP2S60 FPGA
The FPGA refuse to work after I program it! I use two way to program my design, one is programming to EPC16 which is connect to FPGA, another is programming to FPGA directly. but FPGA has no rea...
17 years ago --- Quote Start --- Have you tried measuring the clocks, pll lock signals and resets? Another thing can be to program something else into the fpga. Some simple design that toggles pins or something like that just to see if the FPGA or the design is the problem. Best Regards, Ola Bångdahl (trying to avoid doing actual work...) --- Quote End --- Thank you for your reply. May be ,I see. I'm try to check whether the crystalloid is OK.
