16 years agoHelp me!
Hi every one ! I actually wanna get your hand cause I was doing with EPM7064SLC44-10( MAX7000S) but I have problem with JTAG, I can't load it and now it makes me trouble!.. Please fix me the problem ...
16 years agoAltera's guidelines recommend TCK be tied to GND through a 1K resistor.
I don't have Altium Designer and haven't looked at your schematic. However, I've found that many JTAG signal integrity problems can be solved by adding source-series termination to the JTAG signals. So for example, a 33ohm or 50ohm resistor on TCK, TDI, and TMS right at your JTAG connector. Also, a resistor on TDO coming out of the FPGA. I'm not saying this is your issue. Usually if signal integrity is a problem, you'll at least be able to scan the chain even if only intermittently. Jake
