16 years agoHelp me!
Hi every one ! I actually wanna get your hand cause I was doing with EPM7064SLC44-10( MAX7000S) but I have problem with JTAG, I can't load it and now it makes me trouble!.. Please fix me the problem ...
16 years ago --- Quote Start --- It's clearly wrong to place a pull-up resistor at TCK, a pull-down resistor is needed instead. P.S.: Also the CLK AC coupling seems faulty, but it hopefully wouldn't block JTAG communication. --- Quote End --- Thanks Mr FvM! I'll check the circuit board and try it again. If you have another idea, hooefully we can discuss. Thanks very much.
