17 years ago
help me to translate verilog to vhdl
hello,
is there anyone expert in both verilog and vhdl?? i did learn only vhdl..help me to translate these codes into vhdl..
`timescale 1ns / 1ps
module mctrl(
input clk,
input rst,
output [31:0] wb_o_dat,
output wb_o_ack,
input [31:0] wb_i_adr,
input [3:0] wb_i_sel,
input wb_i_we,
input [31:0] wb_i_dat,
input wb_i_cyc,
input wb_i_stb,
output wb_o_err,
inout [31:0] GPIO,
input [31:0] GPIO_I
wire sel_ram;
wire sel_rom;
wire sel_io;
wire sel_ddr;
localparam RAM_BITS=11;
localparam ROM_BITS=14;
localparam IO_BITS=16;
wire [RAM_BITS-1:0] ram_addr;
wire [ROM_BITS-1:0] rom_addr;
wire [IO_BITS-1:0] io_addr;
wire [31:0] ramdata;
wire [31:0] romdata;
wire [31:0] iodata;
wire ram_ack_o;
wire rom_ack_o;
wire io_ack_o;
wire rom_err;
wire io_err;
wb_bram# ( .ASIZE(RAM_BITS) ) my_ram (
.clk ( clk ),
.rst ( rst ),
.ce ( sel_ram ),
.we ( wb_i_we ),
.addr( ram_addr ),
.dati( wb_i_dat ),
.dato( ramdata ),
.ack ( ram_ack_o )
wb_prom my_rom (
.clk ( clk ),
.rst ( rst ),
.we ( wb_i_we ),
.ce ( sel_rom ),
.addr( rom_addr ),
.dato( romdata ),
.dati ( wb_i_dat ),
.ack ( rom_ack_o )
wb_io my_io (
.clk ( clk ),
.rst ( rst ),
.ce ( sel_io ),
.we ( wb_i_we ),
.addr ( io_addr ),
.dato ( iodata ),
.dati ( wb_i_dat ),
.ack (io_ack_o),
.err ( io_err ),
.mask ( wb_i_sel ),
.GPIO ( GPIO ),
.GPIO_I ( GPIO_I )
reg ack_int;
assign ram_addr = wb_i_adr[RAM_BITS-1:0];
assign rom_addr = wb_i_adr[ROM_BITS-1:0];
assign io_addr = wb_i_adr[IO_BITS-1:0];
wire op;
assign op = wb_i_cyc && wb_i_stb;
assign sel_ram = op && (wb_i_adr[31:30] == 2'b11);
assign sel_rom = op && (wb_i_adr[31:30] == 2'b00);
assign sel_io = op && (wb_i_adr[31:30] == 2'b01);
assign wb_o_dat =
sel_ram ? ramdata :
sel_rom ? romdata :
iodata;
assign wb_o_ack = ram_ack_o | rom_ack_o | io_ack_o;
assign wb_err_o = 0;
// synthesis translate_off
always @(posedge clk)
begin
if (wb_i_we && sel_rom && wb_i_adr[31:5] != 0) begin
$display("%t: Invalid write to ROM: Address %h\n", $time, wb_i_adr[12:0]);
$stop;
end
end
// synthesis translate_on
endmodule
    --- Quote Start ---
    but I have a syntax error when I'm compiling some verilog source (few lines) in a .vhd file !
    The smart way, is to translate my few verilog lines to vhdl code..
    --- Quote End ---
    you can't use verilog syntax in a VHDL-file. You need separate files for your VHDL and Verilog stuff.
    Kin regards
    GPK
    --- Quote Start ---
    --- Quote End ---
    Yes, what's the problem for a few lines?
