8 years agoHelp me my board doesn't work
Hi I'm using de2-115 board and today, it doesn't work...
I used it yesterday but there is no problem When I put my code into board, it became this state. I tried to put default code to factory reset but I stopped at 33% or 49%. Can anyone tell me how to fix this problem?6 Replies
I have seen this before, but I cannot remember how this was solved. I assume you could find nothing helpful on the forum?
https://www.alteraforum.com/forum/showthread.php?t=57127 https://www.alteraforum.com/forum/showthread.php?t=58702 - Altera_Forum
--- Quote Start --- And what is the os and which Quartus version are you using? --- Quote End --- and this is what I can see when I try factory reset https://www.alteraforum.com/forum/attachment.php?attachmentid=15544 - Altera_Forum
--- Quote Start --- And what is the os and which Quartus version are you using? --- Quote End --- I'm using Window 10 and 13.1version Quartus - Altera_Forum
Yes all things are in default position.... I just tried all sof files I have, but it doesn't work
All the config jumpers and switches are in the right position?
Does it stop for all sof/pof files?
