14 years agoHELP me in RS232
can anyone have a look in this coding.....my project using 2 de2-70 board. i want to send data captured from one de2-70 board to another de2-70 board by using rs232. anyone have done this before?urge...
14 years agoHow?? there is the data...how to send to out from one board to another board or how u do..any module?rs232 module?
Sdram_Control_4Port sdram0 ( // HOST Side .REF_CLK(iCLK_50), .RESET_N(1'b1), .CLK(sdram_ctrl_clk), // FIFO Write Side 1 image 1 .WR1_DATA({sCCD_G[11:7], sCCD_B[11:2]}), .WR1(sCCD_DVAL), .WR1_ADDR(0), .WR1_MAX_ADDR(800*480), .WR1_LENGTH(9'h100), .WR1_LOAD(!DLY_RST_0), .WR1_CLK(CCD_PIXCLK), // FIFO Read Side 1 .RD1_DATA(Read_DATA1), .RD1(Read), .RD1_ADDR(0), .RD1_MAX_ADDR(800*480), .RD1_LENGTH(9'h100), .RD1_LOAD(!DLY_RST_0), .RD1_CLK(~ltm_nclk), // SDRAM Side .SA(oDRAM0_A[11:0]), .BA(oDRAM0_BA), .CS_N(oDRAM0_CS_N), .CKE(oDRAM0_CKE), .RAS_N(oDRAM0_RAS_N), .CAS_N(oDRAM0_CAS_N), .WE_N(oDRAM0_WE_N), .DQ(DRAM_DQ[15:0]), .DQM({oDRAM0_UDQM1,oDRAM0_LDQM0}) ); Sdram_Control_4Port sdram1 ( // HOST Side .REF_CLK(iCLK_50), .RESET_N(1'b1), .CLK(sdram_ctrl_clk), // FIFO Write Side 1 .WR1_DATA({sCCD_G[6:2], sCCD_R[11:2]}), .WR1(sCCD_DVAL), .WR1_ADDR(0), .WR1_MAX_ADDR(800*480), .WR1_LENGTH(9'h100), .WR1_LOAD(!DLY_RST_0), .WR1_CLK(CCD_PIXCLK), // FIFO Read Side 1 .RD1_DATA(Read_DATA2), .RD1(Read), .RD1_ADDR(0), .RD1_MAX_ADDR(800*480), .RD1_LENGTH(9'h100), .RD1_LOAD(!DLY_RST_0), .RD1_CLK(~ltm_nclk), // SDRAM Side .SA(oDRAM1_A[11:0]), .BA(oDRAM1_BA), .CS_N(oDRAM1_CS_N), .CKE(oDRAM1_CKE), .RAS_N(oDRAM1_RAS_N), .CAS_N(oDRAM1_CAS_N), .WE_N(oDRAM1_WE_N), .DQ(DRAM_DQ[31:16]), .DQM({oDRAM1_UDQM1,oDRAM1_LDQM0}) );
