16 years ago
HELP ME about EP2C20Q240C8,PLEASE!
HI ALL
I'm using the cycloneII(EP2C20Q240C8).I want to know what the difference the pin 178 and the others.when i use the pin 178 as LVTTL output,it cannot output a wave (frequency about 25MHz when i use crystal about 50Mhz),but when i use other pin,they can do it.why??? THE wave mentioned above is that i see by the signal-tap. what can i do to solve it?
    no! i tried the code without the signal tap,and it still didn't work. i also found the chip become very hot. So i have decided to give up use the pin178.
    --- Quote Start ---
    --- Quote End ---
    That's actually alarming. I don't think, that it happens because you're using a particular pin as output. As a more likely reason, you may have shorted a pin that is driven as output (e.g. an unused pin) or the device is simply damaged.
    --- Quote Start ---
    you mean the signal tap is unbelieveable
    --- Quote End ---
    I mean, that some pins may be unaccesible for SignalTap by it's nature. SignalTap uses existing IO buffers and registers. If these resources don't exist for a particular pin, SignalTap can't work. There are some cases, where SignalTap can't access a pin (e.g. withh DDIO function) or doesn't necessarily reflect the pin state correctly (e.g. input function of bidirectional pins, but only in some cases, depending on other design parameters). I would expect problems also with dedicated clock outputs, but I'm not sure about.
    i use altera fpga many years, i will not let the pin be shorted. the unused pin were made as input tri_stated.But when i didn't use the pin178, the chip is normally cool.Meanwhile i have tried two pcb board to test, the result is same.
    I'm not aware of a known issue with pin 178 of the said Cyclone II chip, if I understand right, you have reported, that it had worked for you in other designs too. So there are two possible explanations:
    - A hidden short on your PCB
    - A Quartus or Cyclone II silicone bug
    In the latter case, you should contact Altera suport with an example design, that reproduces the problem.
