16 years agoHelp in verilog code...
I have given a task of writing a verilog code for moving the stepper motor for desired number of steps in either clock wise or CCW direction . i have written the following code but when i simulate it...
16 years agoThis cannot be corrected.
You need to describe a circuit. What you wrote is a code for simulation that does not correspond to a circuit. I suggest you to read a Verilog book such as: Verilog HDL Synthesis, a practical primer from Bhasker or A Verilog HDL primer from the same author. Among the most important errors: 1) initial : is not synthetizable in a circuit 2) Among the frist line you write i <=n_steps; this means : a wire connects the input n_steps and the signal i so they're equal. After some line you write i=i-4 ?? If i is connected to n_steps it cannot be equal to itself minus 4. Do you want to synthesize a decreasing counter? Put a flip-flop where to memorize n_steps once every while. Then use the memorized value to drive a counter (made with a register and a sum)
