9 years agoHelp how to use avalon interface
Hi everyone,
I'm using a DE1-SoC board. I'd like to transfer data from FPGA to HPS and I have to use the avalon interface but I never used this interface. Anyone can have some document or example? My project consist in acquire data from the FPGA pins and then send data in a SDRAM that is shared with the HPS and finally send to the PC throught the ethernet interface. Anyone can help me? Thank you Gianluca3 Replies
Thank you Johi and Dave, I'm going to read this documents
Best regards Gianluca - Altera_Forum
--- Quote Start --- Anyone can have some document or example? --- Quote End --- The best way to understand the Avalon interface is to use the BFMs to exercise your components or your design. See the tutorial at the top of this page: https://www.ovro.caltech.edu/~dwh/correlator/cobra_docs.html and this one http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial Cheers, Dave - Altera_Forum
Hello gianluca87,
Welcome to the Altera forum. ftp://ftp.altera.com/up/pub/altera_material/13.1/computer_systems/de1-soc/de1-soc_computer.pdf (ftp://ftp.altera.com/up/pub/altera_material/13.1/computer_systems/de1-soc/de1-soc_computer.pdf) Contains a nice tutorial that should get you started. Best Regards, Johi.
