19 years agoHelp for QEye-Ris System vision
I'm working with QEye-Ris system vision, I want to know something about to research of morphology of the shape using CNN. Thanks
19 years agoWho develops this vision system? This probably won't be the correct place to answer your question. The FPGA/Nios is "blank" until the someone creates a configuration/program that tells it what to do. This is similar to going onto an Intel or AMD processor message board and asking how a particular piece of software works. It will be the system developer of the AnaFocus vision system that would be able to help you. (I googled them, but didn't find much, so good luck...)
