15 years agoHelp for counter programme
Design a 4-bit up/down counter with synchronous counting and asynchronous master reset. Write a VHDL design description of the counter based on the following criteria: a) The counter in...
15 years agocurrently, you have set a reset whenever m_reset = '1', you have 2 if branches with enable in them, one for when enable is '1' and one when en is '0'. These branches are actually the same thing as the only important signal is m_reset = '1'.
as for the clock, you want the following code:
elsif rising_edge(clk) then
if en = '1' then
--check count direction and count
end if;
end if;
