15 years agoHelp for counter programme
Design a 4-bit up/down counter with synchronous counting and asynchronous master reset. Write a VHDL design description of the counter based on the following criteria: a) The counter in...
15 years agoso far i have this but i am not sure if i am doing the right thing.
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity mini is port ( en, m_reset, updown, clk : in std_logic; q : out std_logic_vector (3 downto 0)); end mini; architecture flow of mini is signal mini :unsigned (3 downto 0); begin process ( en, m_reset, updown, clk ) begin if (en = '1' and m_reset = '1') then q <= "0000"); elsif(en = '0' and m_reset = '1') then q <= "0000");
